joeym
yep, these ones. color yes, but maybe the wrong one for this track ;-)
i would just remove them, only the short ones from 3:58 - 4:04.
wow!
i think your drumsound improved. you are doing very well in hushing up that you don't use real drums. it sounds quite realistic.
btw, i think parallel (upward) compression is overrated. i used it a lot before, but found out, that you can achieve *nearly* the same effect with conventional downward compression. i've examined this in detail on recording.de (german forum):
Forum - Mixing - parallel compression demystified - RECORDING.de
...and later i saw on GS, that someone found that out before:
Parallel compression under microscope - Gearslutz.com
Yes, I'll be removing those stabs. I wanted that part to sound bombastic, but the stabs were the wrong choice. The GT2 is almost like playing thru a real amp, definitely one of the best modellers around! Greg helps me a lot with his comments on the drums and he should know, he records real drums that sound pristine. I think in the meantime I've managed to find good tones, I just have to make them sound more human. Downward compression? I'll have to read up about that, no idea how to do it.....
Thanx for the help, Jan!
