T
TheNewUnknown
Don't be a Pro Tool.
Hey, I'm a college student with barely enough money for ramen noodles, let alone a great Preamp. I have a Digi002 rack (with 4 built-in pre amps) but need another pre or 2...
I'm trying to decide between the DMP3 or Presonus Blue Tube.
The DMP3 goes for around $160 new and I found an older Blue Tube for $100 used (or 199 new).
Which would be the better buy?
Or is there anything else around that price range that might be just as good?
Someone told me to check out the ADA8000 for another 8 pre's but I don't really know how good quality that is
Any help is appreciated!
.Any help is appreciated!
I tried and was surprised by a ART TPS-II. It uses a tube for each of it's 2 channels, to augment the initial Class A transistor gain stage. This allows you to send as much as you wish in gain to the tube augmenting the output's content of even order harmonics (which is why folks use tubes in the first place). This can certainly warm things up depending on the source you wish to use. For example, I've found an otherwise even sounding Rode NT1-A to come off like a $2k Neumann when worked over on this preamp. Warm and sweet. With fully adjustable impedence it allows for a match with all mics. Something you won't get on budget preamps let alone some of the big dogs. Some have complained of noise, however I found what it was is one must adjust their gain stages along the entire chain and balance things out to get super quiet results. When I'm using anything other than a non efficient dynamic mic it is so quiet I have to check to make sure it's on. All in all a very good value for $179 brand new. Up to 72db of gain as well. Hard to beat IMHO.
