H
HeavyNoise
The Kaotica Eyeball microphone isolation chamber was designed with a do it yourself ingenuity to give any vocalist the chance to produce studio quality recordings without having to record inside an isolation booth. The Eyeball is a foam sphere that slips over the microphone isolating the recording device from poor acoustics. Within the Eyeball is a channel that focuses your voice into the microphone which is located inside the sphere behind a pop filter.
The device's strength is the ability to channel every sound directed at it into the microphone without any negative effects from poor acoustics. This is a perfect device for home recording if you do not want to sound proof an entire room just to produce a professional sounding recording. Instead, use the Eyeball to acoustically isolate the microphone from an acoustically imperfect environment to get the most out of the sounds that are being directed into the device.
Using the Eyeball would be an easy adjustment for any musician. The pop filter perfectly eliminates any hisses, clicks, or pops that may turn up in a recording. I can see this recording apparatus being most useful in do-it-yourself situations in professional studios, basements and jam spaces everywhere where there is the will and spirit to produce focused, detailed, and thick sounding recordings.
