quantifiable measure to explain it - huh! I love the way you put it. Also, the situation gets pretty problematic, because the 'Recognized' scientific community does not seem to provide us (unsatisfied minority
) with any clear leads (if any at all) to where to look for the answers. Maybe it is not in the best interest of the 'recognized scientific community', maybe recognized scientists simply have no idea... maybe they had no time to even think about it, or maybe there is something out there, but is burried somewhere in the dark underground.
So we (the unsatisfied minority) are being left neglected by both: science and industry, we are being left with no choice, but turn to gathering for para-scientific self-comforting lemmas for the soul and ramble through the ashes of e-bay for the 'kitchen table'
. You see, we (analog guys) have good reasons and I'd say "rights"
to be somewhat illogical, often over-reacting and ..well, pretty pissed off overall...heh heh
, so you , digital fans guys, should be more sensetive to us and take it easy... sort of speak
When I was trying to find a sort of sensible explanation of why digital does not deliver to me, I kind of looked at overall process, in very general way and as far from a distance as I could abstract myself from the written literature and compared it to analog recording. So what it looks to me like, is that "human mind" or "the designer's decission" or even say - "limitation of designer's mind" could be the factor or maybe even is the key here( ?????).
I'll try to explain, but if you are not into para-science, then don't waste your time here
So if I am not missing something, the digital recording system can be seen as passage through following blocks/actions/stages:
1. Analize (analize the electrical wave/signal)
2. Identify and select (identify the parameter and select it to be a signal representing carrier)
3. Measure
4. Register. (quantize, assign a "a digital name" - set the block of switch(s) position)
5. Add time mark.
6. Digital data manipulation stage. Intelligent switches position re-aggangement.
Digital data play-back section seems to be less relevant to me, as it simply can be seen as a 'mirror process' and built to reflect the 'input section's structure (or principles) ' but with 'revered result'.
So, let's assume that the technology have reached its top hight on the 'definition' part and system stability etc... so if I still hear something 'not-preferable' at the output, then my pointer will mark stage 6 and, more importantly,
stage 2. These are stages, where the digital system is clearly differes from analog. These stages simply do not have place in analog system.
So, here's where I am leading to. What could be possibly wrong there? You see, the 'designer' after analyzing the signal to the extend of his mind's ability at the moment (stage 1) Identifies a
single parameter which can be measured and controlled and selects this parameter to be a representing carrier of the signal. This is the only parameter will be snapshot registered and used through the entire system.
-You may say: "So what?" This all you need - the Signal Level at moment in time. There's nothing else to it."
-Well, you maybe right. But what if there IS something else to it? Something which we (as 'designers') simply either can not clearly identify and/or measure and register either just do not care to try to search for.
So, if you dare think that there may be something more in the wave signal than just one parameter, then this may point out to explanation of what you get at the output of the digital recording system. You can try to look at digital recording system as a
"one single parameter pass filter", and if the digital recording system is linear, then it is so as long as the chosen by the "designer" parameter is the only the haracteristic of 'interest' in the system evaluation process.
In analog system, the parameters we chose to measure and use the measurements during design and evaluations also get singled out, but it only happens "on paper or in designers's mind", while what ever is being unrecognized or ignored - IS STILL THERE!. In digital system what ever the 'designer' picks and chooses - that is actually what you get at the output-door. This is why I was ranting so much about "human designer's brain factor"....
okey,
btw, I was trying to find something about 'linear systems' theory... just in case somebody wish to dig into for what ever reason... I could not find any sites from quick search, I've found this short article, check it out, not much there, but some basic stuff:
Linear Systems Theory
anyhow,
/later,
