TASCAM MAN
Correct! However, with analog summing, each track from the DAW is sent outside the computer through its own Digital-to-Analog (D/A) converter. So, in order to sum 16 tracks outside of the computer, you must have a 16 channel D/A converter box. These 16 analog channels then physically plug into the summing amp where they get mixed together (with panning capabilities) into a two track output. The two separate tracks (L & R) then get routed back to the computer DAW to be recorded as the final mix.
I use the TLAudio Ebony A4, which has 16 inputs and 2 outputs. Summing amps are generally preferred over conventional mixers because they have a shorter signal path and thus, less electronic components to taint the sound quality. A shorter signal path = cleaner results. EQing, level settings, and effects can still be done ITB prior to summing.
Ok thanks for clearing that up for me !! So I should not have a problem of doing that unless I ever go to DAW recording ,at the moment the digital 24 TK stand alone unit is doing wonders for me although if Id have the room for it Id have my MSR24S and M-3500 settup along with all my other zillion tape based recorders!! I still will be flying mixes from cassette and maybe some 2TK reel to reel (15 IPS) mixes to the 2488 to do a little doctoring up and compilation and possibly finally do some complete masters!!I probably will be using outboard gear(amps,mic pre's,effect units etc)to get a little better realistic analog sound from what I did so far on it (2488 NEO)and Ive already learned a few of the editing features on it.I have yet to mix,master and burn a CD on it. The ease of use(learning curve) really has surprised me and I beleive I will be holding on to this one for a long while.But Tascam should start putting multiple analog outputs besides inputs(need more of them to) on there digital recorders.Id love to fly from 8-24 to my other analog machines sometimes and then do a final mix to a 1/2 TK RR at 15 IPS. So many things could be done with more inputs and outputs on a stand alone digital recorder......i could rattle on here but I nbarely had a cup of coffee so far !!
