db51
In a few days I'll be buying a new computer which will be used mainly as a DAW, with my delta 66 card and Nuendo
I've been researching motherboards for the last 3 weeks, and now my mind is set on an Nforce mobo (the Asus A7266-C, using a 415D chipset, no onboard graphics card).
I found very little feedback on nforce mobos as few people seem to have dared to take the leap and still buy mobos with via chipsets...
Anyway, I emailed M-Audio, they said the only known issues were with Via chipsets, so I should be fine...
There have been reports of some incredible results with the MSI K7N266 which uses the nforce 420D chipset :
http://www.digitalnaturalsound.com/logic_dsp/msg/669.html
Logic running 46 platinum Verbs!
http://www.digitalnaturalsound.com/logic_dsp/msg/702.html
Logic running 41 platinum verbs!
Really I've only heard good things on this board so far, so unless you somehow talk me out of it, I'll buy it!
Although you guys will have tested yours until I get mine so if your results are not good then I'll have to reconsider my mobo decision a 3rd time...well they always 3rd times a charm.
