CyanJaguar
xstatic said:Anyway you look at it, I would rather mix blindly than deafly
....Touche
mshilarious said:OK, let's say you have some ugly noise, -80dBFS @ 15 kHz. Let's say you are monitoring at 75 dBSPL, C-weighted. Using Katz' K-14 scale, that means that noise is something like 9 dB. Most adults cannot hear 15kHz at 9dBSPL. Has nothing to do with training, they are physically unable to hear it.
However, as soon as somebody pops that mix in their player and cranks it, there will be that high-pitched squeal, standing out during quiet parts
Also, the OSHA permissible SPL for 8 hours of exposure is 90dBSPL, A-weighted, not 85dB:
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_id=9735&p_table=STANDARDS
giraffe said:i guess all my shit sucks.
it's not tallent that i need
nor room treatment
it's a sub!
CyanJaguar said:interesting. according to your link,continuous monitoring must be performed if workers are exposed to levels above 85dbs, because damage can occur when one is subjected to extended levels above 85dbs
secondly, music with a lot of quiet parts played at cranked levels sounds oxymoronic, as in a deafening silence
No, that is indeed feasable. It's up to the quality of each of the elements, I suppose. If the sub is better at 80 than the woof there. I guess I'd have to ask myself, though, that if my mains can't handle 80Hz, what the hell am I doing with them? Conversely, if my sub is so efficient way up there, just how accurate is it going to be down at 15? I'd have to wonder.noisewreck said:Glen, some interesting points. I had always thought that you could push subs up to around 80Hz, and setting the crossover point there, which would make the woofers' lives on the mains easier, even if they are capable of going down to say 30Hz. I guess i've been mistaken then?
While speaker diameter is important, there is more to it than that. Way way back when I was a pimply teenager, my first self-owned home stereo had 3-way speakers with 15" woofers (Remember the Realistic "Mach Ones", anybody? ). These speakers had a lot of bass, but they certainly were not even close to being subwoofers. On the other hand, I think we've all heard consumer and pro speakers with 10" - or even dual 10" - woofers that couldn't carry a 60Hz hum in basket.mshilarious said:The factor seems to be at what point does a driver become a sub and not a woofer? Most true subs are 12", I'm using a 10". Interestingly the Mackie 824 is actually closer to 9".
Sorry, CJ. I guess it's the same reason that John Madden says stuff like, "They gotta use the tailback to pick up the blitzing safety coming through the stunting linemen if the quarterback is going to have time to check off his receivers in a cover two." Because that's the vocabulary of American football. And because lay terms didn't work for the first few posts .CyanJaguar said:Why do you guys have to talk in such esoteric language. Use laymans terms darnit I could hardly follow.
"I put a blank tape into my stereo, pressed 'Play' and cranked the volume all the way up. The mimes that lived next door called and asked me to turn it down." - Steven Wright.CyanJaguar said:secondly, music with a lot of quiet parts played at cranked levels sounds oxymoronic, as in a deafening silence
Seriously, CJ, just where have you BEEN for your last 3000 posts and counting?CyanJaguar said:seriously dude, this is homerecording, not professional work. room treatment is going a little too far. That is why we use nearfields.
Unless, of course, by room treatment you mean, carpeting, a couple of couches, and a couple of bookcases. in that case, its all good.
SouthSIDE Glen said:How is it that a pair of 8" 2-ways that come with a Sharp bookshelf compact stereo from Best Buy have only about a quarter of the frequency range and accuracy that that from a pair of quality 8" 2-way passive studio monitors from Sweetwater?
SouthSIDE Glen said:No, that is indeed feasable. It's up to the quality of each of the elements, I suppose. If the sub is better at 80 than the woof there. I guess I'd have to ask myself, though, that if my mains can't handle 80Hz, what the hell am I doing with them? Conversely, if my sub is so efficient way up there, just how accurate is it going to be down at 15? I'd have to wonder.
Could you point me to where that may be stated? I'm not saying you are wrong, or necessarily that whatever documentation that said that is wrong. I just want to read it, maybe I'll learn something. Because based upon my current understanding of physics, there is no "cutoff point" for directionality; degree of directionality is linearly proportional to wavelength; its a smooth function. Maybe I'm wrong about that.mshilarious said:Also, 100Hz is the usually stated cutoff for directionality of sound.
Probably not uncommon.mshilarious said:After lots of testing, I got the flattest response from my system with a crossover at 105Hz.
apl,apl said:How come my 3.1 liter engine in the Lumina can only make a little over 100 horsepower while a smaller 3.0 liter Formula One engine gets about eight times that? Clever marketing?
SouthSIDE Glen said:Could you point me to where that may be stated? I'm not saying you are wrong, or necessarily that whatever documentation that said that is wrong. I just want to read it, maybe I'll learn something. Because based upon my current understanding of physics, there is no "cutoff point" for directionality; degree of directionality is linearly proportional to wavelength; its a smooth function. Maybe I'm wrong about that.
Yet I just can't get past the ideas:
- that if one needs to use a sub to replace three whole octaves of poor reproduction in the mains, then the problem is that they have bad mains, not that they need a sub.
- that subwoofers are supposed to provide subsonics, not bass (even if they are capable of the bass.) Using a subwoofer as a woofer just seems to me to be using a hammer to drive in a slot screw. Wrong tool for the job, even if it seems to work.
Wanna agree to disagree on this one?
SouthSIDE Glen said:Because based upon my current understanding of physics, there is no "cutoff point" for directionality; degree of directionality is linearly proportional to wavelength; its a smooth function. Maybe I'm wrong about that.
apl said:You are correct, to a point.
The sound hits the ears, and the little hairs in the cochlea vibrate. The hairs are tuned to specific frequencies. The brain can sense the phase difference between the 250Hz hair in the right and left ears and uses that to calculate direction, along with some other information like echos off the floor or walls. Since the ears are only so far apart, the phase difference between the ears gets smaller and smaller as the frequency gets smaller, and it's harder for the brain to guess where it's coming from.
BlueSky said:Actually it is a little different than that...
SouthSIDE Glen said:mshilarious:
Ok, my apologies for misunderstanding your actual position. I guess we were just hammering at the technicalities of our arguments. A shame we didn't share a few beers while we did that, it was real bar talk.
I do still think you are placing too much importance on speaker size, though. There are so many other elements involved.There are. However, if we limit the discussion to nearfield monitors in a given price range, most of those variables recede as the designs and driver quality should be similar.
