C
CyanJaguar
Then you are mixing blindly. just the humble opinion of someone who learned the hard way.
CyanJaguar said:Then you are mixing blindly. .
DM1 said:Unless you're mixing country or jazz, or something that has no sub bass.
And there's a reason 85dB is a good level to mix at. It's important to check a mix a many levels, of course, but at 85dB the human ear registers sounds at each frequency most evenly.
lolxfinsterx said:Thats a load of horse crap bub.
My mixes are fine on the lows.
I don nee no steenkin sub
mshilarious said:If you were using 6" monitors, then you are probably correct. If you were using 8"s, you should have been OK. Personally I prefer 6" with sub, but that is just a preference. If you have stuff with real low bass, like 20Hz, then yeah I would say you need a sub. If your sub is not calibrated, then all bets are off.
Also, if you are not monitoring at 85dB, then I hope you are QC'ing your mixes on headphones, because there might be a lot of low-level crap you can't hear. Then you will realize that the headphone check is largely a waste of time if you monitor at a proper level to begin with.
CyanJaguar said:Good post. You dont really have to QC on headphones. you just have to get used to listening at lower levels.
Wow. I guess all those Grammy winning albums that were made long befre most studios had subwoofers and had gear half of which was sonically inferior to what your average project studio has today, and yet still sounded leaps and bounds better than 90% of the indie stuff made today with subwoofers were mixing deafly, dumbly and blindly. And they STILL managed to play a mean pinball.CyanJaguar said:Then you are mixing blindly. just the humble opinion of someone who learned the hard way.
SouthSIDE Glen said:Wow. I guess all those Grammy winning albums that were made long befre most studios had subwoofers and had gear half of which was sonically inferior to what your average project studio has today, and yet still sounded leaps and bounds better than 90% of the indie stuff made today with subwoofers were mixing deafly, dumbly and blindly. And they STILL managed to play a mean pinball.
G.
Many studios may be equipped with 15" mains, but the use they have gotten out of them over the years is a different story.CyanJaguar said:which studios. As far back as I know, studios have been using 15 inch mains that reproduce more bass than most consumer subs.
SouthSIDE Glen said:Many studios may be equipped with 15" mains, but the use they have gotten out of them over the years is a different story.
First, back in the heyday of Abbey Road and such, the gear was incapable of accurately reproducing subsonics, regardless of the type of transducer they eventually pumped into.
Second, I have read and heard more than one modern "A List" mixing engineer say that their big surface-mounted arrays are more for the benefit of the client than they are the engineer. In other words, they're more for show and gear list than anything else because they prefer to do their mixing thorugh the nearfields only. I'm sorry that I don't have direct quotes or specific names here (this is stuff I read while reading and drinking mocha lattes at my local book store), but the source material was from both Mix magazine and from the "Mixing Engineer's Handbook", and these were true Big Boys.
The baseline is that subwoofers are critical in two mixing situations: if you're mixing for 5.1 or greater, or if you're mixing hip hop meant mainly for dance clubs and car stereos with amps and loudspeakers that weigh more than the car's drive train.
In all other situations, subs are nice to have but far from critical for getting a good mix. Much more critical, and a better spending of budget, IMHO, is to pump the money one would otherwise spend on a sub into better mains instead (or maybe even into better room treatment). If your mains suck, the sub is not going to help with anything but the thump.
G.
