Not really. For example, you want to insert a compressor; Click the plug in halfway to get the send signal > take that cable and plug into the input of the comp > run another cable from the output of the comp into the tape deck.
Then run a cable from the tape out jack of the deck to input (s) 5 through 8 for monitoring.
For mixdown you could pull all the cables going to tape cause they wouldn't be needed anymore.
Unless I'm a moron, which is a possibility, that should work.
Alright..... Let's see if I got this.......
Basic Setup
Mic/instrument --> CH 1 mixer ---> out the insert ---> Track 1 on input 4-track recorder ---> out Track 1 output 4 track recorder ---> CH 5 mixer
Mic/instrument --> CH 2 mixer ---> out the insert ---> Track 2 on input 4-track recorder ---> out Track 2 output 4 track recorder ---> CH 6 mixer
Mic/instrument --> CH 3 mixer ---> out the insert ---> Track 3 input on 4-track recorder ---> out Track 3 output 4 track recorder ---> CH 7 mixer
Mic/instrument --> CH 4 mixer ---> out the insert ---> Track 4 input on 4-track recorder ---> out Track 4 output 4 track recorder ---> CH 8 mixer
Compressor While Tracking (ex. Channel 1)
Mic/instrument --> CH 1 mixer --->Repatch standard cable out the insert ---> Y-cable compressor input---> Y-cable compressor output --->Standard cable to Track 1 input 4 track recorder ---> CH 5 mixer
Compressor While Tracking (ex. Channel 5)
Repatch CH 5 to CH 1 mixer ---> Repatch insert cable out the insert ---> insert cable to other end of y connecters at the input and output of compressor---> stereo out
Aux 1 and Effects Return handle all the Nanoverb duties during mixdown and tracking
How'd I do?????
The basic setup looks good.
I'm confused by the Compressor while tracking (ex. Channel 5). Why would you be using CH 5 when you're tracking (other than monitoring)?
And what do you mean by "stereo out?" The compressor is mono. You can't get a stereo out.
I wrote it wrong..... Crap!!.... let's try this again....
Basic Setup
Compressor While MIXING (ex. Channel 5)
Repatch CH 5 to CH 1 mixer ---> Repatch insert cable out the insert ---> insert cable to other end of y connecters at the input and output of compressor---> Back to insert
During mixing, everything ends up going to stereo out so I can send it to the computer.
The "Stereo out" was really confusing.
Is this better?
I am kinda intrigued by RFR's (and Ghosts) hooking two boards together. Could I do something like that with another M-08 board. This is just fact finding right now, although there is another board like mine on Ebay for cheap...... hmmmmm........
Got any pics you can post?
But Brad, why increase your real estate and still lack some essential ease-of-use functions typical to a multitrack setup? I'd be all over an M-106 if I was in your shoes. I'm asking an honest question...just wanting to understand why the M-08, which is a basic live mixer.
Basic Setup
