pipelineaudio said:Can someone point me to any evidence that the electronics of a hi speed dubber would output AUDIO (not tape to tape charge) but actual audio past 20khz?
talontsiawd said:No offence but you have to see that you are posting somewhere that people arn't up to speed on what you are doing. But they are stilling trying to give you alternatives. I'll ask you this. I have an old 71 jaguar xj6 that stalls after idle for 30 sec. I have checked both fuel pumps, they are fine. What is wrong? Is that enough info? Am i in the right place, best place to get an awswer? Maybe you can see that since your problem is unique, you arn't going to get a quick, or easy, or even a good answer necessarily.
Anyway, what i have to add, you can defineatly use 2 audiophile 2496's at once. Infact you can use 5. I've only used 2 at once though and i can assure you that works. Actually any soundcard from the "delta" family will work in conjunction with another one. Now the issue is if the destination (program) can easily work with two cards. I know protools most defineatly can. I would image it would work with 5, i don't know, i would never need more that two.
I'm still using my MQ 2PortSE!xstatic said:Check at almost any universities bid sales. There should be hundreds of 800mhz computers. Lots if windows 98 too
What i really need to find though is an old Opcode midiquest sound card
dickness???Robert D said:The Lynx-L22 should do you fine, I like mine a lot. The only thing it won't help with is dickness, which you seem to have in full 200Khz bandwidth.
