R
RFR
Uhhhh, REALLY?!? Maybe you can get away with using that line on your wife, but not me buddy. Not me.Good news part 3 arrives next week..... then I'll be uhhhhh.... done!!![]()
I think I have her hooked up right, but I have a couple of questions.
With the setup below I attached compressor to the PGM insert jack. So using this setup, I should be able to use the compressor for both tracking and mixing as long I assign the track to PGM 2 buss, right?
There are two types of PGM Out jacks. RCA which has a -10dBv unbalanced output, and the phono jack, which has a 0dBu output. Right now I'm using the phono jacks for the tape in. Is this ok???
I also found a source for the missing knob so this situation will be taken care of soon
Let this sink in. I'm happy to walk you through specific "how would I" scenarios specific to your gear since I'm familiar with the 234 and presently own two M-106s.
I think I already addressed question #2 in post #73...?
.One question about your use of the compressor though...are you doing stereo or mono when you are mixing down? If stereo, one normally uses a stereo compressor on the stereo mix vs just compressing one channel of the stereo pair. Or do you have a compressor on the PGM 1 insert also?
I'd like to give you some guidance on how to best use the combination of the M-106 and 234. Do you always record a single source to each tape track, or do you often submix multiple sources to 1 or 2 tracks in combination with single source tracks? And how many different sources do you have? How many of the M-106's channels do you use for sources?
