Hey Jason! Yeah, I'm happy I finally have something new to share. I guess it's really been a couple of years since I really had anything new like this, although it seems crazy to me that it's been that long. After I finished my CD, I was determined to go back to the drawing board and try to get myself set up to do more organic recordings with a real band, real amps, real drums, etc, etc, etc. So, that's what I've been doing I guess...just going through major gear acquisition and then finding the right bass player/singer to gel with Paul and me and complete the trio. Anyway...I am now set up to properly record the trio format, so I'm hoping that now we'll start to produce more music like this.
Thanks very much for the detailed feedback! I'll definitely take a closer listen at the drums and see what I can do. One thing that stinks is that after the guys left a couple of weekends ago and I started messing with the raw tracks we had recorded, I realized that my right drum OH had something wrong with it...some clipping or distortion combined with a really low overall level. So...this mix is completely missing that right side OH, instead I have the left OH just panned up the middle. My drum setup now is
a Shure Beta 52 on kick, Sm57s on snare, tom, and floor tom, an MXL SDC for hats, and then two Avantone CK-1 SDCs for overheads. I'm still a little unsure about the best way to record drums with this combo...I used to do a sort of Glenn Johns technique when I didn't have the hat mic and all the toms mic'd. Now that I have mics directly on everything, I'm sort of scratching my head about the overheads. For this recording I left them the way I had them in the Glenn Johns config, but I think going forward I'm going to move them out in front a little to try and capture more of just the overall kit. Anywhoo...that could be why the cymbals are low...I'm struggling with a bad OH track. I will see if I can do some automation or something with what I have though...
I didn't actually EQ the guitar at all, except to just cut below 60Hz. Personally, I'm loving the raw guitar tone, it's a Les Paul Junior with P90s through a Marshall 100W head and 4 x 12 cab. I will play around with bumping up the level when the way part comes in during the hits in the middle. For bass guitar EQ, the latest mix (4.6) has the bass bumped up at around 100Hz per a suggestion from TripleM, and I think that really helped to thicken up the bottom end of the bass guitar. Did you listen to that latest mix, or the mix in my first post, which was pre-corrections? I ask because I also added about 2 dB at 5500Hz to the vocals per another great suggestion from TripleM. You guys are both hearing the same thing there, so great minds! Just curious if you are hearing that still in the latest mix. Hmmm...I think I should go back and edit my first post to add the later mixes there...
I've been resisting the urge to double up on guitars, just because this is a trio, and I'm trying to keep the arrangement exactly how we play it live so that we can reproduce it when we decide to go out and rock the Delaware valley
Doubling some vocals is something I've considered though...maybe just a subtle thickening on some of the key lines...?
Thanks again for the great comments. I'll look forward to hearing something new from ACS!
Edit: Here's a new mix with many of the suggestions above -
https://soundcloud.com/davedewhitt/heavy-4-8
Very Best,
Dave
