bouldersoundguy
The file is 32 bit float, but I'm pretty sure that doesn't prove anything about your interface. I've recorded 24 bit files from a 16 bit interface.
ecc83, I am grateful to you for having generated these results. I don't however understand them. I will come back to this info tonight and try to make better sense of it. I am not sure if you are saying that my card is junk, or that it is an okay card relative to other stock internal cards, or if it is an okay card relative to external interfaces... Still working on comprehending the info! Thanks again Dave ! - jonny d
Late to the party, but...
One aspect I haven't seen mentioned yet is that the performance of internal sound cards on Macs can be variable. I've seen some that seem to do a good job like the one above but, on the other hand, many's the time I've used the noise reduction in Audition to fix a -55ish noise floor on some other Macs. I haven't bothered investigating whether it the sound card itself of some kind of mismatch on the input but results weren't very nice on some machines I've received material from.
Beyond that, I have to say that external interfaces are NOT a scam. I have both USB and Firewire units and both work reliably and well, They also give me facilities I need (for example the FW one allows 32 channel recording and playback) while the simple 2 channel USB one allows the use of professional (i.e. XLR) mics and phantom power without an adaptor. The use of a mixer mitigates some of these issues but, as mjbphotos says, by purchasing a mixer and plugging it into your computer you've effectively built an interface anyway.
Only the OP can decide if the built in sound card does everything he needs...and if he's happy, then fine. But, for most people getting serious about recording, the built in sound card has too many drawbacks. You may have decided you don't need an external interface but that doesn't make them a scam. It just means your needs are different (and, in many cases, less) than most hobbyists.
Morning Jonny, you might find this interesting?
Recording Acoustic Guitar
There is another very good article on recording electric guitar in the Aug 07 issue.
With regard to internal levels, my 2496 controls are all set at max. There are two reasons for this..
1) The card defaults to max upon driver install and who am I to argue with M-A?
2) If left at some intermediate value I would be forever checking them!
However, at the risk of "telling Granny....." the levels you RECORD at in the DAW software should be nowhere near "max". For a truly 24bit system, the received wisdom is that average levels should be at -18dBFS. I prefer to run at -20dBFS for no other reason that 2dB don't matter a hoot and neg 20 is marked on most, certainly Samplitude's, meters and -18 ain't!
For a 16bit setup you would in theory come up a few dB on those levels (and risk clipping) but in practice, for a GOOD 16bit system you could stay at -18/-16 or so. In any case, as mentioned before, any source you have is going to be noisier (room if nothing else) than even a poor 16bit digital recorder.
On acoustic, the general guideline is a two mic setup. One around the bridge and the other on the 12th fret. The bridge mic not pointing to the sound hole. For the bridge setting, I have used, straight towards the bridge, from the back of the guitar and over the should pointing to the bridge. I have tried with dynamics and condensers.
My favorite would be, condenser on the 12th fret, dynamic on the bridge.
If you try a couple of different approaches, you will find the sound you are looking for.
For the most part, most of us close mic it because our rooms aren't that good. If you have a good room, then you can use something further out. Using 12th and bridge provides close micing advantages, but helps provide a more balanced final. I suggest two tracks, not stereo so you can get your sound balanced with the faders before you even EQ.
I usually use faders for the two tracks, then group or send to a single EQ to go to the master and treat it as a single instrument.
I think that I follow you. I use a 16 channel board for input with 8 XLR in's so I can easily bring the two mikes in and try to get them right before I go to the DAW. It is actually the only way I can use this board because I use monitor sends to send the mix from all of the inputs to either one or the other, and I can only record two tracks at a time, and one has to be vocal because if I don't sing and play, I tend to get lost in time. Plus singing and playing, trying to do both well, is a lot of the fun of hobby audio for me. Great clarification, thanks DM60! - Jonny D
