sonusman said:I have found the best "exciters" are usually well written songs, musicians that are well practiced, instruments that are well tuned, mic placement that captures the sound the way it needs to be, and a mix that doesn't include mega processing!
I have used some exciters on a whole mix before. The downsides were usually much worse than any benefits.
Ed
Shailat said:What a "classic" response
Its so good I doubt u came up with it yourself
Jagular said:I have found when I record my drum, keyboard and bass parts from my Roland XP-50 the sound recorded sounds very dull compared to the actual sound coming out of the keyboard.
My signal is going into a Soundblaster
TexRoadkill said:Connect the dots my friend.
Apple said:I was listening to a mix on a boombox and although the balances were good, it needed a little sparkle. I compress my mixes just a little bit and that compression takes some brightness out. I was considering adding the high end back with an exciter, as opposed to an equalizer. Good discussion here. I would love to get the details of the compressor trick.
