Assholes. Like Greg shouldn't drum on this one, right? Get over it.
Drunk posting, lolz.
I spent a ton of time messing around with this last night. Here is new mix which I like a lot better. You all gave me some great ideas.
I re-tracked the lead vocal. It's a little less lazy sounding and the pitch is better at least. Any good?
I also removed the fuzz guitars from the 1st two verses just to create some space there and add contrast.
I spent a ton of time on the kick/bass thing and I hope the kick is more audible, but I don't think it's ever going to be super present here for some reason.
I agonized over the cymbals though. It seems like, with these loops anyway, if you want to bring the kit forward to sound bigger, you need to bring up the OHs, and with those come this huge wash of open hats and crashes. Comp is minimal. EQ used to tame the cymbals made the rest of the kit sound too dull and small. In the end, a compromise - the drums are a little more forward, but the cymbals still dominate. I added verb to some vocals and guitars hoping to push those back to be closer to the same space of the drums.
After all that, it probably sounds more or less the same to you, but very different to me. If anyone would care to check back and compare I would greatly appreciate it!
New mix 03/08:
Yup, I think that's better. I don't care much for the overheads but I understand your compromise. I think this is way better.
True. But inspired. I think Greg could drum up a storm on this one. And yes, I'm out of line suggesting it. But in vino veritas.
Fuck, mix two is terrific Pete. I listened the other day to the first mix but didn't get chance to leave feedback. I didn't think the first mix quite gelled, but most of what I would have suggested has been corrected.
The retracked vocal still has an element of flatness to it in spots, but I think it kind of adds to the snarley garagey sound this time. The first version did need re-doing for me and this is much better.
The guitar lead's bedded in to the mix much better on mix2. I think it's maybe still a touch too loud in the section starting around the 2.00 minute mark.
I also think the pause at around 2.26 is very slightly too long before the music comes back in. Don't know if you can tweak that or not with your setup?
The outro bit from 3.38 onwards is absolutely excellent. Love how everything comes together there.
It's quite a different tune for you man. I think a lot of it's down to the vocal - more direct, cuts through more and less of your usual layering. I like it - the last song you posted here sounded a bit like you were still getting used to writing again after a break, whereas this one feels like you've properly found your feet again. I'll be listening to this one more for definite, great work
This track is sick crazy good. Holy crap, I love this.
Still really like it. I like how it starts off sounding British and then turns into not British.
At 2.00, until 2.25, how about a disco kick hammering away - nothing else from the drums except the kick.
I'm going to have to rock at some point. This stuff's too much fun to let you have all of it.
That's a kickass sound, I agree with many suggestions here but I enjoyed this warts and all. I did keep waiting for something to kick me in the teeth in the chorus, sort of like a threat made by the verse but not carried out. Still, you could probably pan everything left and EQ it backwards and I would still like it.
Sounds great. the slide seems to fit better & the effects/other sounds that follow it across the panning work well too.
There seems to be a premature noise just before the resumption of play.
I did wonder what it would sound like with the fuzzed bad given a high pass and dropping a full sounding bass in under it but that's jest my musings I think.
This is cool &, as mentioned, I want a Flac or wave for my portable player thingumie.
This latest version seemed vocally spot on. Me I just think the way the vocals sit in the groove in the version just snaps right into place where is feels right, then contrasts and show its intention.
I was not listening for anything deeper into the mix, just the surface anything obvious, from that view point, I think it is a very solid performance.
Quite different from your usual offering, but I liked it! It took a bit to settle in, but about the half-way mark, I was groovin'.
