D
Deen
Hi,
I just wanted to know if you guys run out of memory too.
I'm using Cool Edit Pro with 256 DDram. I use a SIV
hardware monitor. When I start, with all background
apps in the msconfig off, except sys. tray and scan registry
the reading on available physical memory is about 220,000 KB.
The max available is about 260,000 KB. How do I reclaim some
of the remaining 40. I havent run out when using Cool
Edit yet. But after 2-3 hours of internet with Norton
Antivirus and Firewall on, I check the reading and it's
about to run out. So if I use Cool Edit 2-3 hours, does this
mean I have to restart when the memory runs out every time.
Is there a solution to this. Any secret tweaks you could recommend to save on the memory. Does this happen to you?
thanks.
thanks.
