B
BrentDomann
Has a Dedicated Member.
[P]ressure change takes time to propagate, it does not happen uniformly across the entire room volume at the same time. Instead, near the wall the pressure will build up first, and it will then take the form of a pressure wave with will travel inward across the room. At such a point it's in basic principle no different than a similar pressure wave that came from somewhere inside the volume and simply reflected off the wall.
Extrapolate that to 6 surfaces, and the interactions get a bit more complicated, but the basic idea stays the same; you will have pressure waves moving through the volume and not instantaneous pressure change across the whole volume.
The atmosphere is like a liquid, changes in it can only propagate through it like waves, not occur simultaneously across the whole volume.
[A] pressure change in a medium will always have a localized source. This is because any change in pressure requires a transfer of energy, and even the fastest-moving energy we know of has a top speed.
This, I think, is the answer. There will always be waves that must propagate through a medium. Talking about pressure changes, even when an atomic bomb appears to instantaneously vaporize a building, the heat from the bomb will reach the near side first. Although we can't perceive it because of its speed, the wave of expansion of the building's material as it vaporizes nevertheless moves across the building as it vaporizes.
OK. So I think from that we can say that as long as there is an enclosed space, there will always be room reflections. In other words, don't record dry mono sources.
Here's another question so we don't kill the thread: If you have a volume of gas suspended in a vacuum (say, like a cloud of gas in space), it won't have any walls. Don't say this is impossible - think about the edge of our atmosphere. If a wave travels toward the edge of the cloud, can it still reflect? There wouldn't be any wall against which the wave can bounce, but just as compression will bunch up against a surface and reflect, would rarification get to the (normal pressure) boundary, expand out a bit beyond it, and then, because of gravity, re-compress as it stretches out and then "snaps back"?
