I had this genius idea that I could buy some stuff, and be able to record music...
I've used LDC's for OH pointed the wrong way. I miced a kit with the FT and snare mic cables crossed (apparantly, a 57 gets apretty good snare sound from 30" away, although the FT hits were a little tough to listen to...).
Actually, my best one was the first time I did an on location live recording (live as in "in front of an audience of paying customers). I was also running sound, since I own a big pair of powered monitors. Anyway, when I show up, the nook where I was to set up was about twice as far from the "stage" as I was told, and I ran out of cables. I had a little Beri mixer in my pile o' crap, which I needed to submix the drums before my ancient VS880EX (six inputs, I had no external AD for the last two). So I put the Beri in between the stage and the VS, and ran 1/4" cables to connect the two. The VS tried to fall off a table, and snapped the pin from an RCA jack in the right output (which was feeding the PA). Fortunately, with pliers, and a spare RCA-1/4" adaptor, we were in business in a couple minutes. Everything got mercilessly duct tapped after that. Additionally, there were about two outlets available in the stage area. Nobody in the bar could answer complex questions like "what amperage is that outlet rated for, you know, the one with a 900w powered cab and a bass amp plugged into it?" or "where's the fuse box?" Additionally, the band were late, so soundcheck pretty much didn't happen.
I had wanted to record a minute or two, and play it back, to make sure nothing crazy happened, but the lateness prevented my cunning scheme's completion. The VS can not separate the 'phones out from the master, so I would have had to have turned off the mains, listened, repeat. No time. I found that my headphones were totally inadequate for even telling if I had signal, due to the ambient bleed-through, so I had to set all the levels by eye, watching the crude LCD screen (about half the size of a credit card, if you haven't seen a VS880). There was also considerable panic when the band's decision not to bother bringing a keyboard amp, our only potential monitor, revealed itself in full "you need to turn me up" glory.
Anyway, I limped through the live performance, and got home with the six tracks: Stereo drum submix, two vox, guitar amp, bass DI from SansAmp.
1. No bass track. I had the SansAmp off, as the bass player didn't need to be messing around with a pedal. Apparantly, the parallel out does nothing if the pedal's not engaged. So I had recorded 50 minutes of white noise at -6dB (the VS sounds like moist ass at more comfortable gain settings) based on the LCD meters.
2. No overheads. Condensors like phantom power. I never turned on phantom power. The meters all agreed that I was getting sound. The sound was all coming from the kick and snare mic. Wheeee!
The bass player had parted company with the band withing a couple weeks or a month, so I had to learn the songs based on the b/u vocal mic's bleed. They were not tight, and went off of visual cues, and had gotten used to the drummer's wandering tempos. Took me about 20 hours of tracking to lay the 50 minutes semi-convincingly. Oh, and the recording was supposed to be put to video (never happened) so I couldn't just make up a bass part, as it would have to match the player's movements. A couple of silent or near silent count-ins. Fun times.
I also had to mine cymbol sounds from the b/u vocal mic, due to the OH fiasco. I cut everything below about 8k, did some compressing, and blended up the track until you could hear where the cymbols were supposed to be. Needless to say, the b/u vocals are quite sibilant... For those of you playing at home, we are up to four out of six tracks missing or corrupted.
Moral of the story: I suck. However, the band traded me a 16+4 100' snake for the job, and were impressed with what I salvaged. Moral of the story: they suck.
