Lt. Bob
Spread the Daf!
and can you set it up so whenever you use Reaper it'll automatically do that after you've gone thru the first time and chosen your voices?To add to this:
To add VST's in Reaper, read the section about plug-ins, VSTs. There should be folder that either you created (probably not) or Reaper did. That is where they go. Once they are in the correct folder, open Reaper and it will scan them in. When you add/import the track, select the FX button and select the VSTi, there your voices/sound will appear. Now you just have to wade through until one fits. This takes me more time than actually making the music.
Or do you have to go thru that process everytime?
