HangDawg said:They both still sound thin. It's just the second one now has the boxy sounding guitar with some fizz added on top.
The whole mix is snare and guitar.
TelePaul said:The guitar is boxy....I thought that was the point? But I don't listen to shit loads of metal. I actually liked the guitar tone for this particular genre. I still think the snares a bit too high up. If memory serves, the issue of too little bass seems to be a recurring thing with Metallica!
Is the harmony guitar in the solo (approx two minutes in) a bit high up compared to the main hook?
I like this alot.
NTK88 said:Yes I liked it better that way, and prefered the main hook be in the distance so to speak with the reverb.
Yea there isnt supposed to be bass thats too audible in this song... if thats what hang is getting at. I thought he meant there were no frequencies. Thats why I was confused, I even made a point to boost the sub bass and bass freqs
The guitar I think is a case of shit in, shit out It could be nicer.
TelePaul said:Well I think with music you have to judge everything by its own merits...not every song in the world is going to have a ot of low end...I think people would expect it in a band situation; I always figured every Metallica song had at least one 'chugga-chugga' E5 bit. But then again I know shit all about metal. One thing you might bear in mind is that the easiest and arguably best way to change the timbre of an instrument is to alter the mid frequencies; if you've 'scooped' them, it might be worth leaving em in and seeing how the mix sounds.
NTK88 said:On the center guitar track (which is the most audible one) I have 150 with a 3db boost, and 800 / 1200 with 5 db boosts.
The left and right guitar tracks which were lower in the mix and meant to give a little more color and strength to the guitars 31 HZ with a 7 db boost, 350 HZ with a 5 db boost, and 1600 HZ with a 3 db boost.
HangDawg said:Well, first off +7 db at 31Hz for a guitar does nothing but add rumble. More often than not, you should be high passing the guitar anywhere from 60 to 100 depending on how much crap is in there. I would even add +7 @ 31Hz to a bass guitar or kick drum.
Some will tell you that if you have to add more than +- 3 db with an eq, you're better off retracking it and getting it right with mic choice/placement.
You should learn subtractive eq. It simply works better in most cases.
P-J said:Wow, a great cover of a great song. There's certainly nothing in your mix that jumps out at me as a problem. Like the above poster is does seem like the mids have been scooped a little bit more that necessary, and I ended up with a similar tone when I did the same thing.
Excellent recording though, do you plan to get vocals on it?
NTK88 said:Tele just how much EQing is actualy done in the mix?
Do the guitars usually sound pretty damn close to the record?
P-J said:I know you didn't ask me and I have limited experience but I've found that backing off a frequency before recording sounds quite a lot different to backing it off after it's recorded, especially the crispy mids.
NTK88 said:hmm well I think Im heading over to our little "studio" today, and I talked with the guitarist about testing out some stuff. He told me he didnt really do any tests he just turned on the amp and threw a mic there. That explains alot
P-J said:Ah! That's the mistake I've been making. The comments in my Hell March thread have lead my to monitoring through headphones and noticed that the mic placement makes huge differences with only small movements
