demoniobox
Which one are the best cooledit plugins available ?
is there a list ? what could we use ?
lpdeluxe said:I've used Waves with no problems, and also Auto-Tune and the Sonic Maximizer plug-in. Everything works as advertised. As to what's "best"...that depends on what you want to do, how you want to do it, and what you want to spend. There are freebies but generally speaking they don't have the horsepower of the ones you buy.
The best strategy is to record and record and record, then use the native installed plug-ins and find out what they do, figure out which ones you are dissatisfied with, and go from there. There's no "magic" plug-in or setting. You have to learn what results derive from what you have and where you want to go next. Waves, by the way, is very good. That's why so many of us use their software. But Waves won't tell you what to do. You have to learn that.
Give it some time to load. It took 5 min to load the first time. After that it works just fine. My computer showed that audition was not responding then five min later it loaded Luxonix and I could use the plugin.ace516 said:just hold up back there.. Luxonix is compatible with AA 1.5?????? .. I tried it.. didn't work .. my AA would freeze up and i had to end the program every single time, i tried and tried but i just uninstalled it
