muttley600
Banned
Hi Muttley, and thanks.
I have my first question already. Around the soundhole on the top, there is a channel that has been routed for the rosette. I would rather a plain top (without a rosette), so I was wondering if I could just flip the top over? The routed channel will then be on the underside of the top.
There might be a 'good' and 'bad' side to the top, but looking at them, I can't see any difference.
And I'm thinking about a Tru-Oil finish, because it's easy and looks good (from the examples I've seen). What do you reckon?
As long as you have enough top to sit on the ribs that shouldn't be a problem. I'm assuming it has an even thickness across its width at present. I'd still put the rosette in whatever you decide, it serves a purpose structurally in that it helps stop any splits or cracks that occur at the soundhole from spreading. It also gives a rigidity to that area. Whats the top made of? Hows the bracing? Have you drawn up a work flow?
Tru oil is fine. It's not actually a "true" oil finish strange as it seems. It's basically linseed oil that has a added polymerisers added to give it a better harder finish that you can build relatively quickly and easily. In both application and finish it behaves more like an oil varnish like those on violins.You can get a good looking and relatively hard finish with it. There is a process that is easy to follow that gives excellent results without too much effort. When your ready I'll walk you through it. It involves a lot of prep work and a good deal of time and patience, but no great skill.
