Hi guys,
I did a new mix tonight and I like it better. I think I've solved some, perhaps all of the issues, but I hope I didn't create any new ones. Let me know what you think! Thanks.
Chasing Cinderella - Mix 2
Ryan
Ryan, great work, I see exactly where you went with it. I understand that you are somewhat at the mercy of the clients needs. That can sometimes restrict or limit our ability to mix as we really want to.
That said, IMHO the cymbals and hats particularly have a bit too much siblance now, also the acoustic guitar which is most evident in the bridge. Too much high end (or multi-band compression in the higher registers) which tends to cause them to 'thin' out' which loses energy. It is a such an energetic tune that it needs support to translate that way. You did a great job of capturing the essence and vibe, just want to transmit that now.
Again in my listening environment. the lead verse vocals are still too far back in the mix, but not too low. The levels are really good Ryan, just too far back. I suspect the verb and compression on vox are causing this. (Too long of a reverb?) Are you using a plate? A hall? Try shortening it and see what if feels like to you or try a different reverb altogether., Nothing drastic, but the difference between great and perfect is usually small. I would experiment with different settings.
If I am going to get super analytical, the kick and SNARE drum between verses (when the music goes to full-time vs. half time) loses energy. It has no real open 'smack' as if it is over-compressed or has too much 'top' snare.
Can you Automate your mix? If you can adjust the EQ or verb or compression or all of them for the snare during this part, it could potentially bring up the movement in that part.
All in all, great job. Some songs are more challenging than others. Some mixes really help us grow into our rooms to a greater degree and helps us learn our gear and craft. This seems like one of those.
Much respect and many blessings!
