Building a New DAW - Sound Card?
Aoresteen
I'm in the process of building a new DAW. I will be using Sonar 4.
Here is what I have spec'd out thus far:
CPU: Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache
FSB: 1333 MHz
RAM: 4 GB
40 GIG 7,200 Drive for OS (Win XP)
150 GB 10,0000 RPM Recording Drive
500 GB 7,200 RPM Storage Drive
DVD Burner
Floppy Drive
I have an Alesis QSR that Sonar will be controlling via MIDI. I plan on using my Peavy StudioMix via MIDI as well.
I'm a guitarist and I will be recording guitar instrumentals.
I want to record guitar parts in two ways:
1. Using a mike to record my tube amp
2. Directly from my Rocktron Chameleon preamp in stereo.
All the other instruments will be MIDI tracks from the QSR module. All total I should have about 10 or 12 tracks.
Here's my question: What shoul I use for a MIDI interface? What sound card should I use? Or should I get an audio interface? I've built PCs since 1986 but I don't know much about sound cards & audio interfaces.
Thanks!
Tony
Orlando, FL
FSB: 1333 MHz
RAM: 4 GB
DVD Burner
Floppy Drive
Thanks!
Tony
Orlando, FL
If you want to go the cheap rout you can find usb to midi contraptions for cheap...after all it's just 1's and 0's
I would say skip on the soundcard and get you an interface either usb or firewire if you have it.
