I've heard some God awful analog recordings, which sounded cold and I've heard warm digital recordings and vice versa.Exactly, probably becouse they "compensated" the coldness of their digital recordings with all kind of "warm" stuff (ribbons, tubes...)
You should have added more options in your poll, including "all of the above".
I though of that, but everyone was going to vote for "all of them"
The question is, if you can ONLY afford one part of the chain, which one it would be.
Seeing how most people voted for recording, I'm glad I got my Tascam 414
I know a 4 tracker is never going to be like a reel-to-reel, but it's the best you can expect in Bolivia.
I'm having really hard times looking for Type II High Bias cassettes. I can't even imagine looking for 2" tape...
But I, however, can order some tube mikes, I have a ribbon, a tube pre-amp... But it looks like THE way to go is with tape.
*Goes cleaning and petting his 414*
Oh, before I leave... I have this doubt that just came to my mind...
Can you "over-analog" a recording?
Like, with a ribbon mike, through a tube pre-amp, recorded on r2r (or cassette), mixed on a vintage mixer and mastered though all kind of fancy gear.
What is the worst that can happen? Can it gets TOO warm? TOO noisy?
This is where you are taking a left turn to nowhere. There is no coldness to compensate for. Digital more or less gives you back what you give it. Analog tape doesn't. The 'digital coldness' thing comes into play when you are still compensating for what analog tape does to the sound when you aren't using analog tape.Exactly, probably becouse they "compensated" the coldness of their digital recordings with all kind of "warm" stuff (ribbons, tubes...)
Like cjacek was saying. The sound that you think is 'analog' is really just top notch equipment. It's not about tubes, it's not even about tape, it's about good quality gear, good technique, and good mixing.
The good analog sound you are looking for will not be found on a cassette 4-track, a sub-$500 tube mic preamp, a sub-$1000 tube mic, etc...
It really is the whole signal chain. If you are chasing the beatles and pink floyd sound and only have $1000 to spend, you are out of luck. The equivelent stuff nowadays would cost $3k - $6k for the a mic, $2k for a channel of preamp, 2k for a compressor, a reel to reel tape deck (a good one), and $250 worth of tape for every 10 minutes of recording time.
