Epoxy is evil!!!! It has no place on guitar repair, because it is completely and totally non-reversible. As Muttley said, I use it sometimes while building, but never for repair.
Light ..... sometimes you're so eager to show how stupid everyone is but you, that you gloss over peoples' posts and just reply to the part you want.
I VERY clearly was asking about epoxy only in the context of filling a slot in a nut where its' irreversibility would not be an issue. and when I commented on piano repairs; I said what drove me nuts was people using superglue on wood repairs because it screwed the wood up for correct repairs although I didn't word it quite that specifically. Obviously epoxy would fall into that category also. In pianos neither is useful for much of anything and I believe, let me check ........ ummmmmmm, yes, here it is right here ..... piano wood bears a strong resemblance to guitar wood.
After 30+ years of rebuilding pianos and some years of building guitars, I know just as much about working on wood as you do although clearly there will be LOTS of guitar techniques that you're more familiar with than I am just as there are LOTS of piano issues that I know a shitload more about than you.
But in the context of filling a low slot in a nut ....... if I were going to do that (I wouldn't ....... I'd just cut a new nut), I'd want a filler material that would last and some strong epoxies would last longer than superglue IMO. You may disagree about that but that's ALL we're talking about here.
For wood repairs (which is
not what we were talking about) neither is any good and I can't imagine that you use superglue for that either.
So you're using different criteria for your position and mine.When I mention epoxy ..... I must be a stupid fuck that would use it on wood even though I specifically mentioned one of the problems that would cause while talking about superglue.
I always treat you and your knowledge with the respect due you for years of doing what you do. Considering that I've been doing related work for probably even longer than you, I deserve the same.
Big difference between Muttley and you ....... he's always trying to be helpful while not talking down to people and seems to understand that he's not the only bright light on the string while you usually seem to want to use your knowledge to belittle people.
Doesn't really work in my case since I have the credentials to back up my thoughts but I sure do see you do the same thing to a lot of newbs.
