R
RyanEmerson
This is just a real general question.
For punk/rock music, using a PA-head, what level would you suggest having the Low/Mid/High on, and the the bandwidth frequencies as well, while using a standard microphone? Also, if someone was doing backing vocals with high-pitched lyrics, what would you suggest? The only thing I've found so far, through experimentation, is to cut off virtually everything below 60hz and above 5khz. Besides two vocal mics, everything thing else has separate speakers/amps, so basically I'm just trying to adjust for them.
I know it's a little general, but if I could have some basic guidlines, that'd be great.
Thanks.
Thanks.
