R
RAMI
Guest
.....oy vei......
Am going with RAMI on this one.![]()
Basotect is a melamine foam...
Is it similar to the Sonex-Illbruk Willtec foam...?
What about the Sonex Fabritec panels, that use the Willtec plus a thick layer of cloth on the out-facing surface?
While they don't specifically absorb low-end as dramatically as dedicated fiberglass bass traps, they appear to do pretty good at the mids and upper frequencies, and still some absorption also in the low end.
Seems like they would be a good choice for more broader wall covering....and then you just add a few fiberglass bass traps to additionally target the low end.
I just find rooms that are littered with nothing but bass traps hanging everywhere rather awkward if you are trying to also have a lot of audio gear and instruments in the room...and you don't have a monstrous size room to begin with.
The rooms often end up looking like bass trap storage rooms rather than small studios....![]()
In fact, you've got it quite backwards - you don't need tons of panels to absorb the high end and just a few to absorb the low end. The low end takes a lot of treatment - the high frequency is usually sorted with just a few treatments. Usually, you use thicker treatments that are porous so you can treat both at the same time. A room doesn't have to look completely silly to have good acoustics.....
Foam bad!
No use foam!!!!
No....I get that....but I'm not just talking about high frequencies. With bass traps, they are often hung away from walls and ceilings, with space behind them for best operation....and THAT can make smaller studios spaces rather awkward as it can take up a lot of valuable studio space and turns it into a bass trap storage room.
What I was seeing/asking about the Sonex Fabritec stuff, is that it's often done as wall covering....which means it's not taking up studio space as much as hanging 2x4' traps....and since it works good from the high-end to the mids and some low end, then all that would be needed are a few dedicated bass traps in key spots, and not all around the room as I often see in many bass-trap focused rooms.
The on-wall Fabritec would be for rooms that have hard surfaces all around....
I had excellent results by making 2' × 4' 703 panels and straddling them along the ceiling/wall corner.
I wish I would have measured the acoustic response before and after.
You would still need just as many bass traps, regardless if you've got foam on the walls or not, though - and these bass traps would also treat the high end, so the foam would actually be overkill if the low end were properly treated.
Remember that foam fire scenario someone posted? Scary stuff.
Not all of it burns....only the cheap, crappy stuff that isn't even true acoustical foam.
The melamine/Willtec acoustical foam we are talking about here, is fireproof...and they also make fire-retardant urethane acoustical foam.
I'm not trying to push foam treatments...just trying to understand why it IS used in pro studios, but has become such a no-no for home/project studios.
I find most typical home studio bass traps rather cumbersome space hogs...unless you have pretty large space that can accommodate all those panels hanging around, plus plenty of room for....well, the actual studio gear.
Wall treatments are are not space as big space hogs, so that's a nice option for smaller spaces if you can get the right combination.
Also...I don;t buy into the notion that "you can never have enough bass traps" (meaning the hanging 2x4' panels) in your studio as is sometimes suggested....which is why some project studios look like bass trap storage rooms.![]()
I guess I'm puzzled then as I've seen Sonex Fabritec and some other Sonex-type of products all over pro studio walls, even though they had by design, serous bass trapping also built into their space.
Seems like the last few years everyone just talks about typical 2'x4' fiberglass traps.....but I don't see them in big studios, but I do see the Sonex type of wall treamtents....plus serious bass traping.
Wall treatments are are not as space hogs, so that's a nice option for smaller spaces if you can get the right combination.
Also...I don't buy into the notion that "you can never have enough bass traps" (meaning the hanging 2x4' type panels) in your studio as is sometimes suggested....and which is why some project studios look like bass trap storage rooms.![]()
