Hey guys! I got my first tape deck last week, a Tascam 34. The rubber was all goo, so I changed the belt and the pinch roller. Now it plays and records alright, but has a noise, like something scraping or knocking a bit, especially apparent at 15ips. The knocking noise goes away when I lay the deck down on its back.
After researching a bit, I concluded that it might be a rubber washer inside the flywheel that´s also deteriorated, so I took the flywheel off the assembly, but now I´m unsure how to get the "shaft" in the middle out. I´ve removed the two 2mm allen scews, but it?s not really budging, and I´m a bit nervous about pulling on the part of the shaft, that drives the tape (capstan shaft I guess?), with pliers. Is this the way to do it? The flywheel spins quite freely when I hold it in my hand though, so I´m having second thoughts about my theory. Could there be any other reason for these noises in play mode, when the thing is upright, but not on its back?
Also, I wanted to test whether the flywheel was making all of the noise, so I took off the belt - and I feel that the capstan motor is a bit noisy by itself. I´ve made a little video:
you have to turn up to hear it. It´s not that bad, but my plan is to record quiet acoustic music, and I think after a few tracks, it will be audible. Is it a normal noise, and is there anything I can do to make it quieter? I also just want to know, if it´s a normal noise, because I´m anxious about ruining the motor if something´s wrong, and I just keep running it.
The tape deck was used for a bit in the 80´s, and then pretty much left alone until now. Everything is pretty sticky. Maybe the capstan motor needs oil?
