The module with the kit I got only has USB, Greg, but that's basically the way you record with 'em....I hook a USB cable up to my computer, & Reaper (or whatever daw you use) sees it as a midi input....That's basically it dude...You can have the different pads trigger totally different sounds if you want...It's pretty simple really, this kit was plug-n-play...
I can record the module's internal sounds, but it would only be a stereo track, I can't seperate the different kit pieces with this module using it's internal sounds....Some of the higher-end modules allow this, but I really wasn't interested in that, I just wanted to be able to bang out my own midi, without having to spend hours & hours programming like I've done for years...I will still have to go in & tweak the midi, but it won't be as much as I was doing before...I did a lot of research before I pulled the trigger on these things, & there are some really, really nice e-kits out there, but they're also really, really expensive...There are kits that have modules you can actually load Superior Drummer (or whatever) samples into, & send them to your computer for recording, or to use in a live situation, but again, those are expensive as hell, & would be totally useless for someone like me...
The kit I bought is basically a big midi keyboard with big fuckin' keys that I can swarp with drumsticks for veloctiy senstive triggering...lol..I tried to use my keyboard to do this many, many times (playing with my fingers), but it just didn't work for me..So far, without even adjusting any of the settings in the module (pad sensitivity, changing midi note numbers, etc) this kit seems to do pretty good, & I didn't spend a small fortune for 'em, so overall, I'm happy...I just need to practice on my playing...
![Smilie :) :)](/images/smilies/smile.gif)
