Yes...normalization will "lift" everything proportionally, until the highest peak hits the digital ceiling, and that's as far is all can go.
True.
But again....I'm not seeing that connectoin between that and the fact that you need to zoom into a graphic waveform and check out the amplitude of peaks that are less than 200 ms in duration...?
Why did that even come into the discussion....it confuses the point about normalization of ALL peaks, regardless of their duration.
Again....you should try and make your points/posts more clear and detailed, because that may be the reasons you're not being understond...and not the actual topic of the posts.
![Smilie :) :)](/images/smilies/smile.gif)
The other thing is....you seem to still be over-focused on how the sounds "look"....(see my earlier post #22).
