jjones1700
Learning, always learning
Ok, so it's not an earth changing event, but I finally assembled the DB15 cable I needed to connect my TSR-8 to my MTS-1000.
I decided to bite the bullet and see if I could manage soldering the connectors. After buying a pencil style soldering iron and something to hold the tiny damn things while I soldered, I got it! I actually started off using a 25 connector cable. After getting about 4 or 5 leads into it, I decided to scrap it and use Cat 5 cable instead. Much easier to work with solid vs. stranded!
Anyhow, it works! Now the next step is figuring out how to get it all working with Reaper...
