I no free plug-ins of course are not a much to the high end waves bundles. but say you have £1000 to spend specifically on plugins, would go fo analog or digital? or does it depends on your favourite and works best for you?
Waves are nothing special. If you can't get 99% "there" using freeware plugs, it isn't the plugins' fault.I no free plug-ins of course are not a much to the high end waves bundles. but say you have £1000 to spend specifically on plugins, would go fo analog or digital? or does it depends on your favourite and works best for you?
In any case, as with any chain, the most important analog gear is the front end. $1,000 isn't going to score much - But it'll certainly grab a couple nice preamps. That's the smart money.
Well like 4 you who as the luxury of buying of analogs. So you prefer UAD Plugins than Waves?
There are so many at this point... True's P-Solo, Grace Design's m101, FMR's RNP, that Pre-73 thing (Golden? Can't remember - Nice piece though). That said, there are some really crappy sounding preamps out there also...which preamps are you referring to?? just curious![]()
I dont have Waves..I cant afford or need waves...
I wouldnt even imagine the UAD or TC plugs are better sounding than the regular VST ones either..
they just dont run down my PCs CPU and they are very good $$ value, thats why I recommend them, and because they are all i use I am getting to know them very well..
I think knowing how to use them is far more important than what brand they are...try to make sure you have something to cover any need..Id like a better saturator...that'll be my next purchase
To get the analog gear it would take you to match what you can accomplish with $1000 worth of plugs would take 20 or 30 times that much.
Yeah...but that makes the assumption that a $99 soft version of a $5k hardware compressor (or whatever) is the same thing, and that it sounds as good and does everything like the hardware.
Don't let the plug-in GUI fool you just 'cuz it "looks" the same as the faceplate on the hardware version.
There are good plugs...but they're not always a direct replacement for the hardware they were modeled after. If they were...all the hardware manufacturers would go out of business.
I'm in no way saying that plugs are better than hardware, or even as good.
...unless you have about $50k laying around to invest in good hardware, start with plugs.
Yeah...but that WAS the question the OP asked..."which is better?" (not which is cheaper)...
...so in that regard I guess we are in agreement.![]()
This is what I was replying to. Only 1000 to spend, go plug-ins for sure.
...plus some hardware sit around your studio wasting variable space. but I agree at using plugins.
