W
Wilbur
Here's a quick sample of my current drum sound.
My current recording setup consists of an 90's 16 channel Peavey mixer plugged into a Digitech Jamman Loop pedal. Once the drums are down, I use the "overdub" function to add other tracks, then clean it all up in Audacity. This is an (almost) dry drum track, with the Peavey's wonderful hum almost all removed and a bit of reverb thrown on. Now on to the questions...
-I used a pair of old Unidynes for overheads, one a foot above the left hand crash pointing at the hats and one a foot above the ride. Would a change is the positions help?
The snare is mic'd with a single PG58 (yes PG) underneath at a 45 degree angle ~4 inches away. My other question comes with mic'ing the kick drum however. Currently, after hours of experimentation, this is the best kick sound I can get. I put a Nady tom mic about 6-8 inches away from the beater under the floor tom.
Seeing as the front head has no mic hole, is this the best kick sound I can get?
And yes, real recording equipment is coming my way soon...
(Please keep in mind, I'm a bassist, not a drummer
