Zoom MRS-4
  • Thread starter Thread starter Jimmy2002
J
Jimmy2002
Hi Guys,
Im Looking to buy the zoom MRS-4 shown here http://www.zoom.co.jp/english/products/mrs4/index.php
but im a bit comfused on the specs it say's that it can recorded up to 17 track-minutes in Hi-Fi, 34 track-minutes in LONG, WHAT DOSE THIS MEAN :confused: dose it mean it wil record up 17 or 34 mins, or will it recorde 17 , 34 tracks for 1 minuite,
Im confussed can some one help
Many thanks JIMMY
17 minutes track time in hifi mode means that the 32Mb holds 17 minutes total time in hifi mode. That's 17 min. total time for 1 track. If you concieve of using 4-tracks per song, then each track may be up to 4.25 minutes long. If you use "virtual takes", then that uses up track time, too.
Hifi mode is based on a 32kHz sampling rate, which gives you an audio frequency response up to 16kHz, which is pretty decent but not stellar.
Long-play mode is a low-resolution mode that gives you twice the "track time". It's based on a 16kHz sampling rate, which gives you an audio frequency response up to 8kHz, which is voice-grade recording, at best.
Thanks alot mate you been a great help
Many thanks Jimmy
If you're interested in audio quality, I personally own (and recommend) the MRS-4 and MRT-3.
All samples were recorded off the MRS-4 into an iMac and converted to MP3 format. For knocking out quick ideas, it's been worth it's weight in gold.
http://users.ameritech.net/ubfilms/
ted
