I have a Yamaha MG16/6FX .....
Can this be used for DAW recording and mixing?
here is description
The Yamaha MG16/6FX 16-Input 6 Bus Mixer with DSP has all the Yamaha pro quailities with a straightforward and intuitive layout.
16 input channels
Eight mono microphone/line inputs and four stereo line inputs. Two of the stereo inputs also offer mono microphone input capability. Ten low-noise, high-precision mic preamps
Ten high-performance head amplifiers offer superior performance with any dynamic or condenser microphone. Phantom power
All ten mic preamps feature switchable phantom power for phantom-powered studio condenser microphones. A single switch turns phantom power on or off for all ten channels.
Insert I/O
All mono input channels feature insert I/O patch points so you can add extra signal processing to the channels as required.
Four buses (stereo and group)
In addition to the main stereo bus, the MG12/4 features a stereo group bus and outputs that can be used for convenient channel grouping. Three-band channel EQ & HPF
Smooth musical-response three-band equalizers on all input channels. All mono microphone input channels also feature a switchable high-pass filter that can be used to cut out unwanted low-frequency noise.
Two aux sends and stereo aux return
Two auxiliary sends on each channel-—one postfader and one switchable for pre- or post-fader operation-—provide plenty of flexibility for external signal processing and monitoring. A stereo auxiliary return is also provided.
Illuminated switches
Illuminated on (ST buss assign), PFL (pre-fader listen), and phantom-power switches provide easy visual confirmation of critical console settings.
Rackmount adapters included
Use your MG mixer on a desktop or mounted in a rack-—adapters are provided.
Yamaha MG16/6FX 16-Input 6-Bus Mixer with DSP Features:
* 16 input channels: 8 mono microphone/line inputs
* 4 stereo line inputs, 2 of which double as mono mic inputs
* 10 high-precision mic preamps with switchable phantom power
* 16 editable DSP effects
* I/O patch points on all mono inputs
* 4 buses (stereo and group)
* Main stereo bus plus stereo group bus
* 3-band channel EQ & HPF on all input channels
* Switchable high-pass filters
* 2 aux sends on each channel
* Stereo auxiliary return
* Illuminated switches
* Rackmount adapters included
Yamaha MG16/6FX 16-Input 6-Bus Mixer with DSP Specifications:
* Less than .1% THD+N, 20Hz to 20kHz @ +14dB 600 ohms (ST out)
* Frequency response: 20Hz to 20kHz @ + 4dB 600 ohms (ST out)
* 10 mic XLR inputs
* 8 mono line TRS inputs
* 2 stereo TRS/RCA inputs
* 4 TRS insert I/O
* 2 TRS sends
* 1 stereo return TRS
here is description
16 input channels
Insert I/O
* 10 mic XLR inputs
* 4 TRS insert I/O
* 2 TRS sends
