Freudian Slip
So, I thought I would post this here before I revert to win XP and see if anyone has any brilliant ideas.
Here is the story. I have been running windows xp32 with 2 echo laylas and sonar 6 for several years. All of this time I have been able to run WDM drivers. The setup was really trouble free and you had to really press your luck to get a drop out.
Well about a year ago I decided to go to 24bit audio. 24/44100 to be exact. Everything pretty much remained the same except for the fact that my hard drive became my bottleneck. So I got brilliant and decided to install a raid0.
Long story short I now have a win7 x86, sonar 6, dual layla 24/96, single primary sata drive with a data striped 600 gb audio drive. I am running a intel dg965wh board with a core2duo 2.44 ghz intel chip. I do have the latest win 7 drivers for the echo cards as well.
Problem is now. I can not use wdm/ks drivers for the echo cards. I can use asio but, latency is WAY worse and dropouts are pretty typical. I have searched the net for advise and tweaks for win 7 and have found non solutions.
I am thinking that short of doing a complete software/hardware ground up upgrade I should more than likely switch back to XP...??..?? The only thing that really makes that a pain in the ass is the lack of HD tools and drivers in XP. Setting up data striping in win 7 is so easy but if I want to do it in XP I will have to find a way to boot from usb or something to get the intel raid matrix drivers loaded.
I keep seeing everyone singing the praises of win 7 online but, I really don't think that it's ready to be the work horse that XP is.
What say you? Anyone else missing wdm drivers? Hate windows 7? Will XP mode in win 7 pro allow wdm drivers?
Thanks for any advise.
F.S.
F.S.
