Digital Reason
Okay here goes, I haven't had as much experience doing live remote recordings from clubs etc. as I have in the studio but I have been offered a gig and I just want to double check my setup with y'all so I don't run into any last minute problems.
The club uses a Allan and Heath Gl series console with direct outs for each fader (As do most clubs around here) so what I had in mind was taking a line from the direct outs of the FOH console and sending them into a 1604VLZ console via a 16 channel balanced quarter inch snake (TRS). Okay so this gets the signal from the stage to my mix desk via the FOH console, FIRST QUESTION, if I am coming from the direct outs of the FOH will the volume and EQ moves that the FOH engineer makes be sent to my mix desk?????? Are the direct outs pre or post fader or is it different for every live desk????
Okay next step is to get the signal from the 1604 to the recording medium (in this case 2 16bit ADATS) Since the I need to record 16 tracks at the same time and the 1604 can't route 16 places I thought that I could just run off the inserts (using a mono TS cable) to go from fader insert to designated track, thus controling the volume to tape via the mix fader and sending full EQ to tape as well. NEXT QUESTION, can I send to tape using the inserts without any major problems???????? I have never had to do this before and since I am not using the inserts for anything else when tracking and they do send a deticated post fader output signal I would believe that this is my only option.
Does anyone see any problems with this setup or can anyone see where I can make this easier?????? It seems easy enough as it is but I could be missing something here.
Thanx in advance....
Jeff
Saunavation Audio
Jeff
Saunavation Audio
