wall of noise 9
I have a new system dedicated to recording. Problem is although Cubase 5.1 seems to load fine in this system it doesnt reconize the motu sound card
On the configuration process it appears to identify and work ok with the card but once you load up cubase and try to playback archived files/songs the card appears to do nothing. The external motu unit is just passive as well.
I know this motu system is not faulty becasue I had it in a slower speed Intel based system before
If it makes any difference the CPU is an athlon 1800+ on a SOYO board (via chipset) with DDR ram. The motherboard has a onboard sound chip but I disabled it in the BIOS
When I try to load cubase I get a MOTU pop up screen that indicates that the card is not working correctly and gives you the option to go to the control panel to check drivers. The driver is supposed to be working according to the driver info in the control panel
standard WAV files in windows also do not play back
Anyone been through this?? If so you help would be greatly appreciated
