E
expatguy
If you check out the webpages of more than a few respected professional studios that offer digital recording (even though they may also provide analog) you'll often see that the studios' equipment lists include rather old but respected 16-bit/44.1 mHz digital effects units like the R-7, Rev-7, Yamaha SPX [fill-in-model-number-here] and so on.
Logically, I would assume that running, say, a 24 bit/96kHz recording through a low-bitrate/low sample-rate effects box would have the undesirable effect of degrading the quality of the signal. On the other hand, I am sure these units are in the studios for a good reason. So my question to you studio hands is: When would you use these older units?
Only for analog recordings?
Just to add effects to a headphone mix?
Effects routed in side-by-side with a dry track and then mixed to taste?
Applied only if mixing down to 44.1 kHz?
Basically, I see a lot of these units on auctions and, as a digital recorder, I'm wondering if I would be doing myself any favors by getting one. Keep in mind that any answers could make or ruin the day of someone on eBay.
