			Bobbsy
Boring Old Git
Even matching video, you have to be careful and select what works best.  In the first shot, the hi-hat may be just off centre to the right...then you go to an over-the-shoulder from behind the drummer and the hi-hat swaps sides--and then in the CU of the singer it's right in the middle.  Basically you have to pick a sound stage for the music and stick with it.
The most fun I've had with panning vocals is some of the theatre stuff I've recorded. I recall one where the staging of a duet started with one voice on the left of the stage and the other on the right--during the song they slowly walked towards each other and ended up close together. Because I DIDN"T have the worry of trying to match a video, I could copy this in the recording and it worked really well. I'd also commonly put a singer in the centre and a chorus with exaggerated L/R panning to span the whole soundstage behind the lead(s).
Finally, just to add one other reason for panning instruments (including the hi-hat): besides the vocal needing the focus, some instruments can also share a big chunk of the frequency range with the voice--and moving the instruments off dead centre (even if that's artificial) can help the voice stand out without as much EQ as you might otherwise use.
