This link..
Barefaced Bass - Why nominal diameter tells you nothing about tone
Provided by Dug dog tells it all. The guy nails the "size matters" myth (yes you need a large swept volume to couple efficiently at low frequencies but whilst multiple small cones will work they are not necessarily the most economic solution).
He also puts to bed the myth that 15" speakers are "slow" and lack HF response. We have a 200W Fane 15" in a 6cu ft ported cab* (Celestion design) and if we run a sixer thru' it it sounds very sweet. If hit with 20watts (HT-20) it nowhere near breakup so all you hear is the amp. What it does NOT have is any lack of treble! Sure, it does not have the upper mid bite of a V30 but it is brighter than our Greenback (12" 55Hz jobby). It will not disperse HF as well as a 12 or 10 but in our tiny room we are forced to harken on axis!
*And all it has done for the past 5 years is prop up my printer scanner!
