I would like to really treat one of these rooms well to improve my recordings. I'll be recording electric gtr, acoustic gtr, vocals, harmonica, lap steel. I'll probably go direct on some tracks as well. I have a drum kit too, but I'll likely not be recording drums. So....
Ok here are my options. We have 2 spare bedrooms upstairs and I could treat one of those or treat my unfinished basement (larger room).
Bed1 - 13'9" X 10'2" - one window and one closet
Bed2 - 13'3" X 10'2" - one window and one closet (better view of the Rocky mountains -
OR my unfinished basement. This room currently has plastic covered standard insulation covering 90 % of the concrete walls. I've added some Auralex foam to the exposed concrete and some of the sheet rock that was added in the stairwell and to separate the crawl space from the basement.
There are exposed joists above supporting the floor above - so I could attach sound treatment to those. This room is C shaped with the stairwell coming down in the middle of the room/rectangle. As you come down the stairs there is a furnace and hot water heater exposed. There are 2 windows in the room - flooring is raised wood subfloor with some carpets/rugs down.
See attached pic - this room would cost a lot more to treat acoustically and finishing the basement is not an option at this time.
So, please tell me what you would do and why? Are the bedrooms large enough to get good results? If you need more info, just ask. I'm new at this.
Thanks!
Well apparently I can't post the link to the pic because I don't have 5 posts yet.
Thanks!
