Ok, I've got one,
(and again, I'm still quite 'fresh' to analog recording, so go 'easy' on me here
I'm running a 16-track multitrack r2r into a basic analog mixer. I also have a couple of analog mic-preamps as well.
Ok, my question is this: Which is the best 'signal path' to take when doing a session?
(and by the way, I've been told different methods by others out there, which is why I'm a bit confused & hope to get the 'correct' answer from you guys, since you've all been more helpful to me so far.)
For example, let's say you're starting with a basic microphone, right? Some say to run the mic first into the mixing board, then from there into the multitrack recorder, then back into the mixer.
The second example is: again, start with the microphone, then go into the mic preamp, from there go directly to the multitrack recorder (bypassing the mixer) and then finally go from the multitrack recorder into the mixer.
(does that make sense?)
Again, I'm basically just trying to figure out 'which signal path' is the best, most often used, and one to set-up & stick with, if you know what I mean?
Any help on this would be great guys. Thanks.
