A
AlexW
I've got a project coming up where the band wants to do all the raw tracking live (2 guitars, bass, and drums). I've done this before with good results. I've got a main tracking room that's well isolated and a second adjacent room. In the past I've run the bass direct, placed guitar heads in the tracking room, and placed the cabinets in the adjacent room; routing the speaker cables through a breakout box between rooms. That way I can keep the drums isolated well.
For this project, the guitarists both play small combo amps; so I won't be able to split the heads/cabinets between rooms. If I place the amps in the adjacent room, I'd likely need two 20 ft cables patched through a tuner pedal or something to make up the distance. I'm concerned that this may affect the tone adversely though. Alternately, I could keep the guitar amps in the room with the drums and just try using some gobos for isolation. My tracking room is fairly small (approx. 15' x 20'); so I'd likely get some bleed of the guitars into the drum mics regardless. My room is pretty well treated with bass trapping, but I could still see building up some mud-frequencies in this case. For drum micing I like to use 2 overheads as well as a room mic placed out front of the kit.
I'd appreciate any thoughts you might have. Are the cable lengths as much of a concern as I'm thinking?
