Massive Master said:There are several plug EQ's that I can't get enough of. Most of which are UAD's EQ's (the PEQ and Pultec are quite impressive).
Dynamics on the other hand...
Massive Master said:I'm not a programmer, but I would imagine that it's the simplicity of EQ vs. the complexity of dynamics -
EQ ("Color" aside) -- Cut or boost this frequency by this much, all the time, no matter what.
Dynamics -- The level, the peak, the apparent volume, how "thick" or "thin" the signal, the speed, the timbre, the incomming dynamic range, the attack and release and how it attacks AS it releases -- For starters -- Again, "color" aside, goodness, that's a lot to put into ones and zeros. And to make that reaction relative to *any type* of signal... It still fascinates me that it's even possible in the first place.
And some nice ones - I think the UAD stuff (big surprise) is quite good. But for whatever reason, I always go back to the analog stuff almost every time. As hard as I tried to go with plugs (believe me, if I felt I could get the same quality at around *1/20th* the price...), it only cemented my craving for analog gear even more.
This is rather off-topic, but I'm not sure how compression is non-linear. It's still a sequential modification of a linear waveform based upon a linear equation Aout = (Ain-t)/(r/1). I don't see where the feedback mechanism would be located; the amount of compression on a given sample does not depend upon the resulting amplitute of previous samples.bblackwood said:Compressors are harder because they are non-linear devices - the math is very complex.
pingu said:Is it a long time before we can see the top mastering engineers using only plugins.
SouthSIDE Glen said:This is rather off-topic, but I'm not sure how compression is non-linear. It's still a sequential modification of a linear waveform based upon a linear equation Aout = (Ain-t)/(r/1). I don't see where the feedback mechanism would be located; the amount of compression on a given sample does not depend upon the resulting amplitute of previous samples.
Just curious...
G.
masteringhouse said:Aren't digital outboard devices really just another form of a plugin?
When Weiss comes out with an EQ1 and DS1 as a plugin it may be a bit closer than we think.
Yah, but there are plenty of rooms (like mine) that don't use any Weiss gear, or only use it (read: Weiss, digital) in conjunction with their analog chains...masteringhouse said:Aren't digital outboard devices really just another form of a plugin?
bblackwood said:Yah, but there are plenty of rooms (like mine) that don't use any Weiss gear, or only use it (read: Weiss, digital) in conjunction with their analog chains...
Someday soon, people are going to be able to record...
In their homes...
On a computer...
If I remember correctly, Yes, he was high. I wasn't even there at the time, but I'm sure of it.Massive Master said:I remember way back in '89 or '90 - I was interning in a small studio and the owner was talking about:
I told him he was high - Which he probably was, but that's not the point...
