Noise Floor Test
Still looking for answers to my noise problem, I came across this article. thought it might help someone.
My audio interface (Aardvark Pro Q10) is powered by the computer.
http://realcare.intervoice.com/voicerecording/sf_noisetst.html
Noise Floor Test
A high noise floor is a common cause of poor audio quality and clicks in compressed files. Recordings made with high background noise will not provide a clear voice sound during playback. Always check the background noise and a noise floor of the recording studio and equipment before starting a recording session.
Perform this test regularly on systems used to record voice messages.
To run the noise floor test:
1. Ensure that:
1. Microphone levels on the preamplifier are set correctly for a recording session, that is, as loud as possible without causing clipping.
2. Recording attributes are: 11,025 Hz, 16 bit, Mono.
2. Make a silent recording:
1. Ensure that the recording studio is as quiet as possible.
2. Open a new sound file.
3. Record five seconds of silence at the standard volume level. (Do not speak while recording.)
4. Close the Record dialog box.
3. Set the DC offset removal:
1. With the sound file window open and that window selected, select Process > DC Offset. The DC Offset window appears.
2. Ensure that Automatically detect and remove is selected.
3. Click OK.
4. View statistics:
1. Select Tools > Statistics.
The Statistics window appears.
(Be sure the appropriate sound file window is still selected.)
2. Verify that the RMS level (dB) is below 60 dB (for example, –65 dB).
3. Verify that the Average value (dB) statistic is 0.
4. Click OK.
The voice message fails the test if the noise floor is louder than –60 dB.
Note Louder noise is represented by a lower negative number; for example, a –55dB noise floor is louder than –60 dB. Noise floors greater than –60 dB (for example, –55 or –50 dB) can be heard in the playback process, can degrade the quality, and can cause pops and other audible degradation during the compression process.
A noise floor test may fail because the room noise is too loud due to items such as air conditioning, PC fan, or a paging system, or if the sound card preamplifier is noisy.
5. Correct any problems before continuing to record.
