pohaku
The microphone. No doubt about it. While you could argue that a crappy pre can ruin a wonderful mic's sound, the fact that decent pres are as cheap as they are makes that point moot. The same cannot be said about microphones. You can get some very good pres at $25 a channel. You can't get nice microphones at $25 a channel (except for SDCs). You certainly won't be able to find mics that match most sources at that price.
It's all about diminishing returns. As you spend more money on any given component, you get less and less improvement in quality. The difference between preamps and microphones is the rate of the curve. The difference between a cheap pre and a $2000 pre is certainly there, but it isn't even in the same ballpark as the difference between a cheap mic and a $2000 mic.
With mics, you don't even need to jump to $2000 to see the difference. The difference between a $20 mic and a $200 mic is huge. The difference between a $20/channel pre and a $200 pre is usually negligible, and in many cases, the cheaper ones sound better, depending on the manufacturers in question.
Thus, if you're going to spend money, get a decent pre once, then spend further money on your mic locker. After you get something with reasonably high gain and low noise, throwing more money at the pre is likely to give you far less bang for the buck than getting another mic that is significantly different than the ones you already have.
+1 And eloquent besides.
The difference in sound between different mics is typically much more substantial than between different preamps.
