currently im using cakewalk pro 9,and the yamaha xg-50 driver.i love the sequencer of cakewalk and would like 2 continue to use it.i want more sounds,i would like 2 be using high quality sounds like korg or you know,proffesional synth sounds.
1.are there any good soft synths,and are they used the same way as the xg-50 driver(choosing the sound through track properties)
2.ive heard that soft synths are "slow"....what is meant by this?
3.can you effectively and easily hook up an external synth module via midi cable to your computer and have your sequenced song from cakewalk play the sounds you select on your module....how does this work and what settings are involved?
4.im also considering getting a roland pc-200 mkII controller along with a module.but still would like 2 use cakewalk for sequencing.
5.factor number 5 is that i plan to do digital recording into my computer.could i run a midi sequence from cakewalk out to a module,from there the sound into my mixer and back into my computer for recording all at once????
thank you for reading my situation...what i would like to know is what you all would reccomend based on your knowledge and experience
thanks
thanks
