I want a new snake for connecting a Tascam M208 (8x4x2) with an M-Audio Delta 1010, and I'd like to know what kinds you all have used with memorable results (good or bad) - help?
Thanks,
Glenn
Thanks,
Glenn
MadAudio said:I refuse to buy Monster, mainly because of their business practices.
Adam P said:Its probably best to build your own for a couple of reasons: it's cheaper, you can get high quality stuff, and its good experience.
SonicAlbert said:I've found the cost comparison between building your own single cables versus store bought to be different than the cost comparison between building your own snakes versus store bought.
With single cables it is much more cost effective to build your own, in my experience. However, when it comes to snakes I've found the pricing to be a lot closer. If you also factor in time, assuming you feel your time has value, then it is actually the same or less expensive to buy pre-built snakes.
I've done both, and at this point I build my own single cables and purchase pre-built snakes.
Adam P said:Very true. Since I just moved and am still looking for a job, I have some extra time on my hands and don't mind it (especially considering I made an 8 channel Mogami/Neutrik snake for around 60-70 bucks).
On a somewhat related note, would the Belden 8450 or 8451 cable be acceptable for making microphone cables? They're both 22AWG (which I know is light) and have a foil shield with drain wire. The 8450 has solid stranding, while the 8451 has 7x30 stranding; otherwise they're the same. I guess what I'm asking is if the light guage and foil shield are appropriate for mic cables or not, because you can get a roll of 1000ft of either one for under $125, which sounds great to me.
treymonfauntre said:i got a hosa snake (i think it had packaging for another brand, maybe livewire?, but the cable clearly says "hosa") for $10 at guitar center. i told the manager there who was in a HUGE rush for some reason that i thought i saw it in musicians friend for $15 so he said "fine, i'll go down to $20" (it was for some reason $40 new??), so i told him i'd just wait to buy one and he said "hows $10 sound?". for $10 its not gonna break my heart the day it stops working... actually it'll be a blessing cause i can finally upgrade my snake!
SonicAlbert said:The problem with foil shield for mic cables is durability. Mic cables get moved around a lot, abused, twisted, yanked, coiled and uncoiled many times. The foil will degrade fairly rapidly under those circumstances. That's why braided shields are used with mic cable.
SonicAlbert said:A drain wire style cable that would be okay for mic cables is made by Connectronix. It's called MusiFlex. It has a conductive plastic shield, and is extremely flexible. MusiFlex is great cable, I love it. I think the only time to avoid using it would be in situations where you would know that you'd be dealing with a seriously intense RF problem, like if you are doing a gig next to a TV station transmitter. In normal circumstances MusiFlex will be fine. I've never once had RF interference problems using it.
